Chunzliu, le il y a 1 heure et 22 minutes.
Path of Exile is a game built on experimentation. Every league, players push new mechanics, test atlas trees, and chase the next broken farming strategy that prints currency. But not every idea works out. In the Mirage League, we set out to test several high-investment farming strategies that, on paper, looked promising. In practice, however POE currency, they ranged from underwhelming to outright miserable.
This is a breakdown of four major farming experiments-Abyss, Blight, Expedition, and Ultimatum catalyst farming-that failed to deliver consistent value. While none of these mechanics are entirely « broken, » our experience showed clear issues with pacing, reward structure, and overall profitability.
Abyss Farming: A Slow, Frustrating Experiment
Abyss was the first and most disappointing strategy we tested. The idea was simple: use Abyss mechanics to flood maps with monsters, similar to Breach farming, and scale XP and loot through sheer density.
On paper, it looked strong. Abyss Scarabs increase the number of abysses per map, while additional modifiers spawn even more monsters inside them. The atlas tree also supports this approach with nodes that boost monster count and experience gains.
However, reality painted a very different picture.
Abyss is fundamentally too slow. Unlike Breach, which instantly floods an area with enemies, Abyss mechanics crawl forward, slowly spawning monsters as the fissure moves through the map.
Sometimes it forms pits that briefly spawn additional waves, but the pacing remains inconsistent and sluggish.
The biggest issue, however, is the Stygian Spire mechanic. Instead of rewarding fast clearing, Abyss forces a strange contradiction: you must kill monsters quickly enough to prevent the Abyss from stalling, but also slow down drastically when the Stygian Spire appears to avoid accidentally overkilling it and breaking the encounter flow.
This creates an awkward gameplay loop where you are constantly shifting between speed-clearing and restraint. It feels unnatural and punishing.
To make matters worse, Abyss can randomly fail due to pathing issues, especially in Lightless Astrolabe content where full completion of Abyss chains is required. When Abyss breaks, the entire investment collapses.
Even after multiple attempts-including three full farming cycles-the returns were disappointing. Occasionally, we saw small bursts of currency, but nothing comparable to Breach or other meta XP strategies.
In the end, Abyss feels like a mechanic stuck between two identities: too slow for modern mapping, but too punishing to fully scale.
Blight Farming: Low Reward, High Setup
Next up was Blight, a mechanic that historically has had strong niche farming potential, especially through Blighted Maps and oil drops.
The goal was to farm Blight Ravaged maps and capitalize on high-value oils, particularly golden oils and stacked reward chests.
At first glance, recent changes looked promising. The Blight tree had been adjusted to improve item quantity and accelerate monster spawning through Immune Response nodes. In theory, this should have increased efficiency.
But one major issue broke the strategy: map selection.
In previous leagues, maps like Toxic Sewer allowed players to force favorable lane layouts, often resulting in one or two lanes. This is crucial because fewer lanes mean more concentrated rewards in Blight encounters.
In Mirage League, that consistency was missing. Without optimal maps, Blight encounters frequently split into multiple lanes, diluting rewards and lowering efficiency.
Even worse, the Scarab system introduced new complications. The Blight Scarab of Blooming, for example, changes the mechanic entirely by removing structured Blight rewards and replacing them with generic loot chests. While this creates quantity spikes, it destroys the core reward identity of Blight farming.
Other scarabs, such as those increasing boss spawns or ravaged map frequency, performed inconsistently. Despite multiple farming sessions, we never hit a jackpot scenario of 15-25 Ravaged maps in a single chain, nor did we see any golden oil drops.
The result was a strategy that felt cheap to run but equally cheap in returns.
Blight didn’t fail mechanically-it simply lacked meaningful scaling at higher investment levels.Expedition: High Difficulty, Low Reward
Expedition farming was the most mechanically demanding strategy we tested, and ironically, one of the least rewarding.
The idea was to fully juice Expedition encounters using new scarabs like Expedition Scarab of Infusion, which increases difficulty and rewards per remnant. Combined with modifiers that increase runic monsters and explosive coverage, the goal was to create ultra-dense Expedition maps.
In practice, however, Expedition’s scaling problems became obvious immediately.
The mechanic forces players to carefully select remnants while avoiding devastating modifiers. At high difficulty, many remnants become unplayable-granting immunity to your damage type or massively boosting enemy defenses.
This creates unavoidable failure scenarios where players must skip 50-60% of remnants, reducing both difficulty scaling and reward output simultaneously.
Unlike other mechanics, Expedition does not reward full engagement. Instead, it punishes it.
Even with optimized setups, the gameplay felt slow and restrictive. One major issue was that improving clear speed often required sacrificing loot potential, while maximizing loot made encounters nearly impossible.
We also experimented with Mirage logbooks, hoping for rare jackpot drops like unique timeless jewels. Unfortunately, drop rates were too low to justify the investment, and no significant returns were seen across multiple farming sessions.
Ultimately, Expedition in high investment form feels like running endgame Delve content-but with worse rewards and more restrictions.
It remains viable at low investment, but as a high-end farming strategy, it simply doesn’t compete.
Ultimatum Catalyst Farming: Too Random to Rely On
The final experiment was Ultimatum catalyst farming, focused on Mirage variants and stacked scarab setups designed to maximize rewards per encounter.
The logic was simple: catalysts are valuable, and Ultimatum can generate high-density encounters with strong reward scaling.
To push this further, we used scarabs like Bribing and Dueling to manipulate trial structure, ensuring longer encounters and guaranteed bosses. We also experimented with corrupted eight-mod maps to increase quantity.
However, the results were inconsistent at best.
While individual Ultimatums occasionally produced strong rewards, most runs felt underwhelming. Catalyst drops themselves suffer from low demand outside of niche crafting scenarios, which limits long-term value.
Even Mirage-exclusive catalysts, such as Dextral and Sinestral variants, were too rare to reliably farm. While powerful, their drop frequency was too low to anchor a strategy around.
Another major issue was encounter design. Ultimatum mechanics like Stone Circles and Survival modes remain frustrating and cannot be fully removed. These encounters slow down mapping significantly and often appear back-to-back, creating repetitive and tedious gameplay loops.
Despite occasional profitable maps, the overall strategy suffered from excessive RNG and inconsistent reward flow.
What Actually Worked This League
While many strategies failed, several others stood out as clear winners.
Breach remains the strongest XP and currency hybrid strategy, especially when collapsed and heavily juiced. Its speed and density still outperform most mechanics.
Delirium combined with Beyond proved extremely powerful, creating one of the most enjoyable and rewarding mapping experiences of the league.
Legion and Essences also performed well, offering consistent returns with minimal setup complexity.
Harvest remains a top-tier staple, providing reliable crafting value and currency generation. Alongside it, King’s March bar farming emerged as one of the strongest economic engines of the league, especially when combined with optimized shipping cycles.
Finally, Delve exceeded expectations. Shallow Delve in particular proved to be one of the most efficient early and mid-league farming methods, outperforming even Expedition in some cases.
Final Thoughts
The Mirage League highlights an important truth about Path of Exile: not every mechanic scales well into high-investment farming.
Abyss struggles with pacing and design contradictions. Blight lacks reward scaling and map consistency. Expedition is too restrictive at high difficulty. Ultimatum suffers from RNG and outdated encounter design.
Meanwhile, older or simpler mechanics continue to outperform them due to consistency, speed, and reward reliability buy POE orbs.
In a game as complex as Path of Exile, efficiency often beats ambition. And sometimes, the best discovery isn’t finding a new broken strategy-but realizing which ones are better left behind.
