Kongyawen, le il y a 40 minutes.
In Aion 2, mounts and pets serve practical purposes in addition to being cosmetic. Mounts your travel across the vast world of Atreia, while pets assist you in combat or expand your inventory. Acquiring a mount early on buy Aion 2 Kinah saves a significant amount of travel time.
You will usually obtain your first mount through the main questline or as a starting reward. Additional mounts and pets can be acquired via quests, events, or the cash shop. Some are purely cosmetic, while others offer tangible benefits like increased speed or extra storage space. Consider the utility they provide before making a purchase.
Cosmetic mounts and pets are a matter of personal taste and do not affect your character’s strength. Invest in these only if you can afford to do so; otherwise, prioritize gear. Your Aion 2 Kinah is often better spent on powerful equipment than on expensive cosmetics.
Conclusion: Get your first mount early through quests and utilize pets that offer practical benefits. Prioritize gear and save you for meaningful investments. This way, you can travel comfortably while remaining strong.
Another aspect of mounts and pets is their social dimension. Unique mounts and pets often spark conversation within the community and serve as an expression of your personal style. Many players collect them out of passion and enjoy showing off their acquisitions. This is a valid part of the fun, even if it doesn’t impact your combat prowess. If collecting brings you joy, treat yourself—provided your budget allows for it. The key is to keep your priorities in check and not neglect your combat effectiveness. Ultimately, a balanced approach—combining useful investments with personal enjoyment—makes for the most fulfilling gaming experience.
