- Ce sujet contient 10 réponses, 3 participants et a été mis à jour pour la dernière fois par
TiMnZb, le il y a 6 années et 5 mois.
Bonjour à tous. Je possède une Blizzard 1240-T/ERC, et je recherche la disquette d’installation plutot l’adf. J’ai installé des pilotes générique librairie « Mu680x0Libs » d’Aminet :
The mmu.library project © 1998-2018 the mmu.library development group, THOR
—————————————————————————–Release 46.14.3
– This relase provides a new version of the 68030.library
which includes now better support for the 68EC030
processors, especially on GVP boards. For these boards,
caching needs to be disabled for the entire lower 16MB.
Typically, the MMU and the mmu.library do that, but not
if an EC processor lacking a MMU is in the system.
– Updated scripts (installer scripts and rexx scripts) to
support older ACA boards and install ACAInit if such a
board is identified or requested by the user.
– Updated MuGuardianAngel which failed to test whether it
AllocAbs() had been patched over after MuGA was run.Release 46.14.2
– This release provides a new version of the 68060.library
which includes now a more careful test for the I4 bug
of the 68060. Apparently, the test used before could fail
to detect the erratum on revision 5 68060 processors.
– This distribution also includes a new (still experimental)
MMU setup helper « ACAInit » that opens the MMU pages for
some older ACA (icomp) cards such that ACATune will
hopefully continue to operate on them. To use ACAInit,
copy it to LIBS:mmu, and add this command at the end of
ENVARC:MMU-Configuration. Feedback welcome.J’ai plus de message d’erreur au démarrage du workbench 3.1.4. Mais est ce que çà correspond à cette carte ?
Merci pour vos réponses. Bon Dimanche.
